Results 1 to 15 of 17
Thread: No spark honda
    hondaatcvabeach is offline At The Back Of The Pack Arm chair racerFirst time rider
    virginia beach
    241
    No spark honda
    I just picked up a 1981 Honda 200 for $100, it is pretty clean but I cant get any spark. I checked the coil, wire, plug and all the conections and they are all good. What am I missing, any advice? Oh buy the way the timming chain is good also.
    1985 Honda 200x (200s motor)
    1984 Honda Big Red (200ES)
    1985 Honda 250SX
    1984 Kawasaki KLT 250
    1984 Honda 70 (Daughters)
    1981 Harley Davidson Roadster
    PROUD TO BE FROM THE LAND OF COTTON
    Check out my units website 3dvirginia.com
    *******GO DIXIE********
    renotrikeguy's Avatar
    renotrikeguy is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Reno,Nevada
    433
    have you tried cleaning the points? When I got my little 185s it didn't have any spark either. My older brother cleaned the points and it fired right up. How dows your carb look inside? Might need to be cleaned?
    Chris (Reno,Nevada.)
    67 Honda CT-90
    75 Honda ST-90
    81 Honda 250r
    85 Honda 250es BigRed
    99 Honda XR250R
    04 Honda CRF150F - Cousins Ride
    virginia beach
    241
    I cleaned the carb out. I havent checked the points, I'll give it a try. Thanks
    1985 Honda 250SX
    May 2002
    Dublin, Georgia
    635
    Stator
    Don't forget to check the stator assembly. If it is bad there will be no spark.
    84 ATC200X--Wife rode it once, now I can't get it back.
    84 ATC250R--Trying to find piston for 300R kit.
    85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
    84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Re: Stator
    Quote Originally Posted by renotrikeguy
    The 185's did not have points. They use a CDI ignition.
    Quote Originally Posted by ejc042
    I agree here 100%. 9 times out of 10 ten the Exciter coil goes bad. Take a ohm meter and check the black with red striped wire. You should have 215-240 ohms. The lower the ohm reading the less spark you will have.
    Howdy
    Houston,Texas
    1,044
    Hey,do the 80' 110s have points? I hear points are easy to work with just in case my 110 starts acting up. thanx
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by hondatrikesrule22
    Yes, the 1980 110's do have points. Or at least they should unless someone changed the whole electronics out with a newer model.
    Howdy
    Houston,Texas
    1,044
    Ok cool,the electrical looks pretty simple. Also, how do you adjust the timing? It is not as fast as it should be, and when it gets into the high rpms, it bogs down. thanx
    Miami
    were would the stator be located on a honda 83 200s
    Mar 2007
    Texas
    5,045
    under the CDI cap. the stater is the center peice that turns. it has 2 springs that hold it in and as it rotates faster it starts to move out advnacing the spark for mroe power up top in higher rpm's. if the springs are bad, or it's rusted shut it won't spark right.
    there are 3 screws that hold the pickup. loosen them up and you can rotate the pickup but you need to be careful, too much advance and she no workie either.
    ________________
    https://www.mikesatvfix.com
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    Quote Originally Posted by oscarmayer View Post
    The stator coil would be under the left sidecase behind a flywheel wouldnt it? Not sure on the older 200's though, just though they should all be like that, points unit or not.
    PastRides
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Mar 2007
    Texas
    5,045
    ^ ok i called it the wrong something . sorry. i still am not 100% on the part names, but that mechanical thingy i was thinking of is what I was refering to. the 125m i jsut did had a frozen one and when i tried to use it to start the trike the first time, no go. had to repalce it and then VROOM!!!
    ________________
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by jonathan400 View Post
    The stator is located behind the flywheel. The flywheel is located behind the pullstarter.
    Oscar,
    The item behind the CDI cap is called a spark advancer.
    Howdy
    Miami
    ok i got there but but i can't get the flywheel off. i have broken pullers trying
    Mar 2007
    Texas
    5,045
    you have to order an acutal flywheel puller from online. i also used an impact on the but to remove mine as the inital snap seems to help get it off faster and with less damage actually.
    ________________
