Thread: 1985 Honda 200x connecting rod options?
    ky
    88
    I’m wanting opinions on what connecting rod people have used with good results so far I’ve found 2 options. I’ve also heard that an XR200 rod will work can anyone confirm this?
    Links:
    https://www.mfgsupply.com/at-09135.html
    Or
    https://www.ebay.com/itm/Honda-ATC20...gAAOSw~XpZQVvU
    Willamstown PA
    5,824
    xr200 is the same.
    there's OEM rods out there yet or repos. Not sure I trust a repo rod.
    repo https://www.ebay.com/itm/HONDA-ATC20...frcectupt=true
    OEM https://www.ebay.com/itm/Honda-13201...5Ms1:rk:6:pf:0
    weisco promodes the use of PRO-x rods on their site under the 200x 83-85 bike. Id trust a pro-x rod. because i have personally used on on a 14.5:1 raptor 660r motor.
    ProX Racing Parts are an excellent economic alternative when you are looking for an OEM replacement product. They are mainly manufactured in Japan by reputable Original Equipment Manufacturers to ProX's exact specifications and high quality standards. ProX leads the industry in cast and forged pistons made specifically to replace OEM parts.
    Part Number Price Item Type Attributes
    Submit 03.1253 $85.46 Connecting Rods
    http://www.wiseco.com/ProductSearch.aspx
    the two you provided are cheap chineese repo's. In that case I'd choose OEM if your rod is bent or worn. For the same price I'd upgrade to a new aftermarket rod per below: You just need to search harder with parts the engine builders use.
    Aftermarkert https://www.ebay.com/itm/Pro-X-Racin...frcectupt=true
    Most of the top end parts used between the following cycles/atvs were the same.
    Fits:
    1984-86 Honda ATC200S
    1983-85 Honda ATC200X
    1980-83 Honda ATC185
    1981-83 Honda ATC200
    1979-83 Honda XL185
    1979-82 Honda XL125
    1980-82 Honda XR200
    1979 Honda XR185
    ky
    88
    Thank you oldskool, the prox was what i was wanting and couldn’t find thanks for the link.
    louisiana
    1,499
    Shindy and vesrah make good rods also
    Signature pic removed,becuase of no helmet.
