Page 5 of 7 FirstFirst ... 3 4 5 6 7 LastLast
Results 61 to 75 of 105
Thread: Progressive Spring Kit for 85 250R
  1. #61
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by DDQ View Post
    The best forks in the world can't help a bike that won't crank.
    ouch!
  2. #62
    DDQ's Avatar
    DDQ is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2015
    Aberdeen, NC
    414
    Forks are back on! Now I am just waiting on the pipe to arrive.
    Is this the correct path for the clutch cable? It seems like it will be too short at full right turn.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  3. #63
    Las Vegas, NV.
    2,489
    Not quite, but no too far off either. It should go in front of the top triple-clamp, then through the welded on wire guide (in front of radiator, near the top), then it goes above notch in radiator protector grill, and in front of the bottom radiator-to-frame mounting bolt, and behind bolt below the radiator (this bolt should be holding a cable guide for the clutch cable as well).
  4. #64
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    I can not see the welded on wire guide in front of the radiator. Can you circle it?
  5. #65
    Las Vegas, NV.
    2,489
    No need to circle it, as you're going through it already.
  6. #66
    Jan 2013
    minnesota
    5,911
    Here's the factory routing diagram for an 85 plus another photo..
    http://www.3wheelerworld.com/showthr...or-you-Kintore
  7. #67
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    Thanks!
  8. #68
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    Are there fender supports that these knobs rest on? I do not see any on the parts diagram.
  9. #69
    Las Vegas, NV.
    2,489
    No, there are no fender supports on the frame. If those are OEM fenders, there is a support rod that slips into both knob's holes (L & R side of fenders), and bolts to the bottom side of the fenders. Look at the parts fiche for the rear fenders, and you'll see what I'm talking about. I don't believe aftermarket (Maier) fenders have provisions to mount the support rod though.
  10. #70
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    That is what I needed to know. Thank you.
  11. #71
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    I spent a couple hours trying to figure out how to get an air filter to mount to the 36pwk.
    A trip to lowes and some thin steel pipe got me here which is enough to attach a uni filter and outerwear to one more piece of steel pipe.
    I did discover I do not have all the rear brake parts I need. I am missing the spring, connecter arm and whatever else goes between the pedal and master cyl.
  12. #72
    Las Vegas, NV.
    2,489
    Yes, you need the spring, splined brake push arm, and then brake rod pin, washer, and cotter pin to connect it to the rear master cylinder.
  13. #73
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    Installing front brakes.
    I found this in my parts bucket and got excited but I think it is for a banshee.
  14. #74
    Las Vegas, NV.
    2,489
    I'm not sure what bike that spring is for, but it's not the correct one for your 250R.
    Here's what you're looking for:
    https://www.ebay.com/itm/1985-1986-H...frcectupt=true
  15. #75
    DDQ's Avatar
    May 2015
    Aberdeen, NC
    414
    Can anyone offer advice for removing a stuck piston from the rear master cylinder?
