Results 1 to 7 of 7
Thread: 85 250r problem bogging
    Jan 2019
    US
    12
    Rebuilt motor and carb starts and idles fine but Boggs down when hit wot . No difference when u adjust air screw in or out ..help please?
    Sent from my SAMSUNG-SM-J320A using Tapatalk
    Slidell, LA
    4,738
    Need more information than that. Need details of rebuild and details of carb.
    6,811
    Did you install an aftermarket CDI lol .
    Slidell, LA
    4,738
    How dare you ask for more information from Slippery ...........this is an exercise in ball busting........you figure it out ........and then it`s your fault the bike runs bad ........whats a leak down test ?.........i don`t need that !!
    I have so much to learn from the great glamster. 1000 Hail Marys in order for me kind sir.
    Carthage NY 250r rules
    2,355
    Try another coil.
    250r rules
    Sep 2018
    north florida, usa
    Does the engine bog and quit entirely or is the bog momentary where you can throttle through it and the engine runs OK ? Put a fresh plug in it, get it to bog and them pull the plug. If the plug is dry the problem is likely fuel-flow. If the plug is wet, perhaps there is an ignition problem. The air screw only controls low speed mixture and has almost no effect at W.O.T. Good luck.
    Van down by the river
    3,874
    Didja look at it? Ya just gotta look at it.
    R.I.P. John Swinehart
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
