Thread: Idle question.
    Apr 2018
    Gresham, OR
    47
    Idle question.
    Hey guys. I have a 1985 200S. It is in amazing shape, starts right up, runs good but has an odd idle quirk. It idles fine but then about every 5 seconds it sorta hics or pauses for a fraction of a second and then continues to idle along okay. Any ideas what that is?
    6,819
    Very common issue on the 200s model , Honda put a 35 pilot jet in the carburetor and its to small , install a #40 pilet jet and fine tune the air fuel screw and the hiccup will be gone .
    Apr 2018
    Gresham, OR
    47
    shortline10: Thanks for the insight. Sounds like an easy fix. I will get to it. Thanks.
    Dec 2012
    812
    Would this apply to the other 200 models as well or was it just the S?
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    6,819
    If it uses the 35 pilot jet then yes , Most 200 models use a 38 which is ok and in most cases a fine tune with the air fuel screw takes care of the hiccup .
