Page 2 of 2 FirstFirst 1 2
Results 16 to 25 of 25
Thread: WTF: Found 2 alum wheels.....
    N/A
    5,818
    I would of filled the hold with weld before ever painting the rim. Your going to get slop into the seats of the beat.
    Jul 2018
    TN
    1,065
    No, Like I said...and I just finished doing it....I put a larger self tapping screw in the hole with red locktite. I had to use a ratchet to do the final tightening and they are TIGHT. They ain't coming out. Ground the bead side smooth. All good now. It looks like a lot of the other custom wheels out there with faux bead lock bolt heads. If I do decide to repaint them again, I will just sand blast them too and paint everything. ....or I could replace them easy enough. Dirt in the bead won't be an issue anyway if I run these on the Goblin. It will be for suburban sneaky sneaky riding and that means asphalt and manicured lawns. LOL!!
    Feb 2017
    Arkansas
    530
    Gives the wheels character. If you are looking for show quality then no. It's a good tenor look.......ten or twenty feet away.
    In the design world they would call that "patina"
    Jul 2018
    TN
    1,065
    It would be interesting to know just what happened. I sand blasted and etch primed these...gave them 24 hrs. Scotch brite and 3 coats of paint....gave them 24 hrs. Used the spray bedliner and it looks like I sprayed them with wd40 beforehand. Strange.
    I did it all in a heated shop too, so it wasn't temp related.
    Scootertrash's Avatar
    In the sticks
    4,638
    Sometimes spraybombing can be a paint in the arse
    Jul 2018
    TN
    1,065
    I've had really good luck in the wintertime. Summer months with the humidity...not so much. I have wires hanging from the ceiling directly over the wood stove. Get the wood stove rolling and you can dang near do a baked enamel...LOL!!
    Seriously though, I have actually got the parts so hot hanging over the stove that the paint flashes and I have to strip it and do it again.
    Not sure what happened this time. Spray bed liner usually covers ANYTHING. I've used it a lot over the years. This is the first time it's crapped out on me.
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    ... It isn't like he rectum. On a more serious note, spraying a lacquer based paint over an enamel based paint can cause a crackled effect. Great for creating an aged patina on wooden furniture, not so much for refinishing wheels.
    In the sticks
    4,638
    Quote Originally Posted by Gabriel View Post
    It was a pun Gabriel, not a mis-type
    T-dog caught it, like always. Putting a pun or double entendre in a post is to T-Dog is what the Bat signal is to Batman!
    tripledog's Avatar
    Aug 2011
    Central New York
    2,182
    I'll be here all week...
    Jun 2009
    Leander TX
    2,217
    Like this post if I should leave it and run it. If I leave it, I think I will put them on the Goblin. It's a facked up pile of crapola anyway. Dislike if I should repaint. LOL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    I've also decided to since I'm running tubes, I won't bother filling the holes.
    I don't think those holes will cause air leaks.
    Run ugly wheels on ugly ATV. Sounds like a perfect match.
