Results 1 to 7 of 7
Thread: 1981 110
    Nov 2018
    IN
    30
    1981 110
    If anyone has a picture of how the wiring harness is routed I’d appreciate it. Wrapping up my restoration and when I bought the trike the harness was missing. I know the CDI goes on the upper tab by my arrow, Still tracking down the rubber holder for it. Im just not sure on the rest , there’s another tab below that but it’s been damaged from what I can tell. Also not 100 percent sure on the routing of the brake cable through the forks .
    Any help would be appreciated.
    Thanks Click image for larger version.
    Nov 2015
    Davenport iowa
    1,144
    The harness needs to pass through your frame. The opening you see up towards the front of the trike on that side and it comes out of the opening above your top back mount, once you do that it will all make sense. The front brake cable runs down where you have the harness now.
    Show us a pic of how you have your front brake cable now
    1974 original 90 X 2
    1974 Original 70.
    Nov 2018
    IN
    30
    Coming through the frame makes total sense now ! Thanks . I’ve restored or replaced everything on this bike other than the original OEM plastics . Including engine rebuilt from bottom to top so getting excited for the finish line .
    Nov 2018
    IN
    30
    One thing just became painfully obvious... I gotta pull the motor to properly run the harness through the frame .
    Nov 2015
    Davenport iowa
    1,144
    Quote Originally Posted by Yzfireguy815 View Post
    You may be able to pull the top rear mount bolt and loosen the bottom, pull the front mount and see if you can swing it out of the way enough.
    1974 Original 70.
    Nov 2018
    IN
    30
    I’ll give that a shot . Thanks
    Nov 2015
    Davenport iowa
    1,144
    Looks good, nice job. Your brake cable routing looks to be correct I also think that the throttle cable routes the same way.
    1974 Original 70.
