Results 1 to 12 of 12
Thread: 1985/86 ATC250R radiator shrouds
    Oceanside, CA
    89
    So I've found a spot that has factory sealed OEM shrouds for a killer price. There are 2 different part numbers for each side. I'm just curious what the differences are between the two. Same price for each.
    Here are the numbers...
    19030-HA2-000ZA vs. 19030-HA2-670ZA
    And
    19035-HA2-000ZA vs. 19035-HA2-670ZA
    Any light shed on the subject would be appreciated. Thank you all in advance!
    Also, I'm going to ramping up on my ATC500R conversion before too long. That thread will get updated whenever that begins.
    Slidell, LA
    4,738
    Or you can just buy them brand new from partzilla.
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by Hedbngr18 View Post
    And
    In this particular case, the last numbers of 000za are the number they originally used in 1985. The 670za number means they made some type of change to the part but it is designed to replace the original part. The 000za part has been discontinued so it is no longer available from honda, however, the 670za part is still available at $61.75 retail from any honda dealer or as low as $44.15 from some dealers if you have a dealer account like I do.
    Las Vegas, NV.
    2,528
    No differences between the years, that I've ever seen. Only reason I can think of for 2 different part #'s would be for the standard shrouds, and the short course tank shrouds.
    Jan 2013
    minnesota
    5,911
    In any event they are the most bitchenest shrouds in the world !..........whats the bitchenest price out there ? .........$44.15 sounds good barns..........did you bring enough for the whole class ?
    They are only $47.00 thru partzilla. Most of their prices are really low. If I didn't have a dealer account at the local dealer, I would get my stuff from partzilla.
    San Marcos Ca.
    715
    And
    Hay Jason , give me a call or a text. I got a new phone and loss some of my contacts. You were one of them. This just happen two weeks ago. JW
    * 1970 US90 Red
    * 1985 ATC 200s
    Oceanside, CA
    89
    Partzilla.com is where I'm currently looking. They have a few in stock of each part number, so I was just curious if there was any advantage to one or the other. I'll just go with the later model for no reason whatsoever. Haha These are going on the 500 later. Thanks for the input everyone!
    Jan 2013
    minnesota
    5,911
    They will not have the 000za number in stock.
    Man, I just keep buying a set of these 250R shrouds with every Honda order I make. As well as 250R and 350X forkboots, I keep adding to my stash.
    I cannot find ANY INSIDERS to tell me if American Honda has 300 sets left or 3000!!
    It seems IMPOSSIBLE to get that statistic. A couple years ago the 350X shrouds went away, no one knew ahead of time (to my knowledge). So, they went from 50$ to about 220$ a side which is the going rate now. Why couldn't anyone warn us ahead of time?? I would have bought 10K worth of 350X shrouds if I knew they were going by by....
    There MUST be a way to get that inventory...
    Mexico
    9,018
    That's an easily answered question....
    Just walk into your local Honda dealer and tell him you want to place an order for 1,000,000 sets for ATC 250R shrouds. When he says "Sorry sir, there are only XXXX available" you'll have your answer.
    In the event that he says, "Ok sir, your 1,000,000 sets of shrouds will be here in 6 to 8 business days, will that be cash, or credit?" you'll know you shouldn't have bothered hoarding them all these years
    It sucks to get old
    Williamstown PA
    5,825
    They a e the same order with hre foe new frames and everything else that gets wadded up. Manufactures know what's still hot, there is a reason we can still buy parts cuz parts have a 40-60% markup ware the whole machine does not. Buy the parts but don't blow all your money hoping in 5 years to make it back. Ebay helps if your not smart ebought to find the part numbers. Cool thing now is partzilla puts the part next to a ruler, this saved me $26 today in bolts for a ytm. I just cut a ton of stainless ones I had down to the lengths online...
    Slidell, LA
    4,738
    Do you get marketing kickbacks from Mike at HRE? Just curious cause you mention him in every other post. Is he good, yeah, I’ve had plenty of stuff made by him by jeebus chreesto man, expand your horizons.
