Results 1 to 3 of 3
Thread: axle/sprocket drive hub
    Jul 2018
    TN
    1,065
    Does anyone know any tricks for removing the drive hub that's pressed/splined on a 200S axle? I would like to get it off without ruining the part. I may need it on another project someday.
    This rear end I am rebuilding today will be used in such a way as it won't need a drive sprocket so I would like to remove it.
    If I can't get it off without messing up the axle threads, I will just cut it off.
    ....what a crappy time for my torch to run out of O2.
    Willamstown PA
    5,821
    take it to a machine shop and give them a few bucks. They are pressed on tight from factory then rust in place.
    Jun 2009
    Leander TX
    2,217
    x2 - I had one pressed off a 350X axle and, even then, the guy at the machine shop said it took a LOT of push before it popped.
    I reinstalled it myself after having the axle zinc coated. I heated the hub to about 300 in the oven (afraid to melt the rubber). It still took a lot of and drift work to get it on.
