Results 1 to 14 of 14
Thread: 84 atc 70 - idles but won't accept throttle
    Feb 2019
    PA
    I posted some of this information in a different thread earlier, (just realized I can start a new thread, so here goes).
    Bought two atc 70's, a Christmas Special and an 84. The 84, I'm trying to get running so I can ride it. The Christmas Special will be restored to glory.
    The 84 ran at a very high idle when I first got it, and barely would gain rpm's when you gave it throttle, it would rather stall. I cleaned the carb and it got worse?!?!
    I have since adjusted the valves and points and tightened the timing chain tensioner. I cleaned the carb extensively; it's the stock carb with the stock jets in there, which I believe are 38 and 58. It seems like a fuel problem but I have noticed some indication of blowback through the carb.
    I have good spark.
    Went over everything last night again and it fired up first pull but seemed to be giving me the exact same issue. It idles but will stall if you go to give it gas.
    Any thoughts on this matter oh knowledgeable three wheeler forum?
    It's likely you have a leak at the intake manifold gasket.
    Jul 2018
    TN
    1,065
    Yep, most likely a vacuum leak. Ever so gently mist some starting fluid in and around the carb and intake. If the motor speeds up, you found it.
    Feb 2019
    PA
    I like those ideas and have a new manifold gasket that I can try. Before the most recent adjustments, I attempted to spray either in the air filter and it didn't change anything.
    Appreciate the suggestions.
    6,811
    If the points are old replace them , OEM only , they are big part on how the spark is advanced when you accelerate . Their is no mechanical spark advancer or CDI , it’s all done threw the points , adjust them to .016 .
    It’s also very important on the stock carburetor to have a perfectly sealed air box which includes the intake boot .
    Jul 2016
    Kentucky
    61
    Agreed. I’d replace the gaskets, replace and set the points with a light bulb if you can and order a new carb. They’re cheap, just be sure to tighten up that screw on the butterfly inside before you install it, I’ve had several come loose. Might as well check the valves too. Be sure you’re too dead center on the compression stroke for valve adjustment. Otherwise it might not ever start for you.
    Feb 2019
    PA
    Update:
    It wasn't a vacuum leak. I tried propane and either and neither made any difference, actually you can spray either in the air filter and it doesn't do anything.
    Did a compression test and it was low, like 88psi. So I figured why not just put this 88cc kit on it. I did that Saturday night and unfortunately I still have the same problem. The bike starts and idles fine, but won't rev up. It doesn't exactly stall either when you give it gas, just doesn't do anything. We did notice the valves weren't seating 100% so we lapped them and the result put us in spec according to the manual.
    I suppose I'll buy a new set of OEM points, although the points look new, maybe they're aftermarket and junk? I had the points set at .035mm or something to that affect...following the service manual.
    I have a metal mesh air filter on it, not the stock air box so it's definitely getting enough air and when you choke it that's no improvement so I don't think that air is the issue.
    Again; I appreciate the suggestions. Thanks!
    Jul 2018
    TN
    1,065
    I will get flamed for it by the purists but a points delete kit is cheap. They're pretty simple to wire up and you don't have the points to deal with anymore. Points are great....until they ain't. More to them than just the gap. The contacts need to be parallel to one another. Not sure how the dwell can be adjusted as I've never touched Honda points to my knowledge.
    Anyway...it's an option. I've done it to several older engines and it always works fine.
    6,811
    Your problem is the missing “AIR” box , the stock carburetor will not accelerate without it .
    A clamp on filter will not work on a stock carburetor !
    Your options are either buy an aftermarket carburetor or try and find an OEM complete air box assembly .
    Feb 2019
    PA
    Can someone point me in the right direction to purchase OEM points? And possibly an aftermarket carb that would be suitable.
    This red 84 came with a kehin on it that's not the stock carb, but I am using the stock carb (from the christmas special) to test with since I know it's the right one. I have tried the carb that came on the bike multiple times, but maybe it's got the same issue because I'm not using a stock air box??? Wouldn't the choke (at some level) replicate the restriction of the stock air box and therefore let it run right, even if it was just for a second? I'm asking because that never happens.
    Again, the help is appreciated.
    6,811
    Part number 1 and 3 should be replaced at the same time , both available new from Honda .
    https://www.partzilla.com/catalog/ho...0-a/alternator
    These guys are local to me and their carburetors seem to work good .
    https://www.ebay.com/itm/Honda-ATC-7...ty!33331!US!-1
    Feb 2019
    PA
    I picked these items up and also a new head. One of these things should do it! I'm getting frustrated and I'm just going to take the anger out on the throttle...eventually!
    Feb 2019
    PA
    Guys; I just wanted to say thanks for the recommendations and suggestions.
    It turned out to be a bad condenser. After I replaced pretty much everything else on the machine.
    Now I have an 88cc kit in it and I need to get the jetting correct. I'm going to start a different thread. Thanks!
    Apr 2019
    earth
    I just joined the group and signed on and was reading your comments. We used to change condensers on most all points replacement in my shop years ago, but you issue did sound like a fuel related problem. glad you got it fixed. (if anyone cares to know that a condenser does, The condenser absorbs electric voltage vs jumping the gap when points open, That would cause a drop in primary voltage charge to the coil.this is called magnetic induction, where as 12 volts converts to thousands of volts, hence the spark)
    My first post, I promise I will not be this technical again.
