Results 1 to 3 of 3
Thread: klt200 flywheel puller? SOLVED
    May 2011
    The Granite State
    914
    so im working on a KLT200. 1984. Every flywheel puller i see on the net (including motion pro #08-0027) says M16 x 1.5 pitch. Well i used a tap to check and M16 is to small for my flywheel and M18 1.5 seems to be the fit.
    Has anyone taken a flywheel off? Did you use the motion pro? thanks
    86 350X ::: 85 250R
    Projects
    350x
    Come and Gone
    86 350x : 84 250r X2
    85 350x X2 : 84 200es X3
    83 200e : 78 ATC90
    It's been awhile for me on a kaw but I think I just used a bolt that fit.
    May 2011
    The Granite State
    914
    The correct size at least in the case of my 1984 KLT200 was M18x 1.5
    86 350X ::: 85 250R
    Projects
    350x
    Come and Gone
    83 200e : 78 ATC90
