Results 1 to 3 of 3
Thread: Good carb kit for 86 ATC125m
    Mar 2019
    Monroe, NC
    16
    Anyone have any recommendations on where to find a good quality carb kit for an 86 ATC125m? I've noticed that they are readily available for the 84-85 years but not so much for 86-87. Only one I have found so far is the All Balls kit 26-1756. Anybody had any luck with that one?
    Apr 2014
    Edmond, KS
    2,591
    My opinion is that you only want to use the gaskets in most, if not all, rebuild kits. Sometimes the jets can be the wrong size even if they have the right size stamped on them. I can only assume that the needle is the same way too. I'll clean and reuse the factory jets and needle. If you want to replace them, a good place to find them is jetsrus.com. They sell genuine Kehien and Mikuni jets and other parts.
    Mar 2019
    Monroe, NC
    16
    Copy, thanks for the advice. It looks like i can still get the gaskets from Honda and I'll replace the jets through your jetsrus.com recommendation. Thanks for your time!
