Just finished with our latest motor. Bored, stroked camed 110 motor running with this real cool ( never before seen) Mac pipe. We are just now in the tuning stages and need a little advise as to the direction we should start. We are running a mikuni 22 mm carb main jet 100. The trike starts, idles and has good response to 3/4 throttle. 3/4-wot it surge's. Tried a bigger main but the only one on hand was much bigger than the 100 and the surge worsened. Dropped the needle 1 clip down, no difference. I am assuming I'm not pushing enough airthe reason I think that is because our other 110 (bored only) is running a 24mm mikuni.
Would removing my air filter give me a clue as to if I'm
Starving for air. Should I just start with a 24mm carb?
I've also considered putting a 185 carb on if it will fit with the shorty intake we are running. I also have a flat side carb size around 30 without measuring it
Anybody have any thoughts here? Again I've just started testing and tuning just looking for somewhat of a starting point.
