Page 2 of 2 FirstFirst 1 2
Results 16 to 23 of 23
Thread: Latest motor build.
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by DAM shop View Post
    I can't try a longer intake without robbing Peter to pay Paul.
    Then just don't tell Peter you robbed him.
    Jan 2013
    minnesota
    5,911
    You should also test it by riding along in 3rd gear at 1/2 throttle or slightly higher on level ground for a few seconds, then rapidly opening the throttle for around 3 to 5 seconds and see exactly what it does. Do this several times before you change jets so you have a good feel for what it is doing.
    Below is a general list of conditions to look for when doing this particular test.
    Engine has a noticeable hesitation upon initially opening the throttle quickly from 1/2 way to full open like it is running out of gas or air, but it does not pop or burble or surge = Lean on main jet, plus the needle may possibly be too low, but a low needle rarely causes a big hesitation so I would try a different main until the problem is minor.
    Engine has a noticeable miss/burble and possibly some popping upon initially opening the throttle quickly from 1/2 way to full open, and the problem becomes less as the rpm increases. = Main jet too big. Try 2 sizes smaller . If the problem does not decrease during this test and it does not rev much higher. it is likely that the main needs to be reduced by 3 sizes but I would try just 2 sizes first.
    Jan 2013
    minnesota
    5,911
    I also only use oem jets, not replicas/aftermarket ones, because the aftermarket jets can meter/flow fuel at a slightly different rate than an orig can even though they are both stamped the same size and this can confuse the flock of of a person.
    Jan 2013
    minnesota
    5,911
    POST CORRECTION CUZ ME NOT GOTS NO EDIT BUTTONZ
    "flock of of a person."
    Should read:
    "flock out of a person."
    6,784
    Mac pipes is still in business. I sent them a pic of this pipe. They said they made them for the 90/110 and 185 in the day..
    Looks like a POSA made pipe to me , excellent quality and sound !
    Nov 2015
    Davenport iowa
    1,144
    yes i learned my lesson on Jets long ago.
    1974 original 90 X 2
    1974 Original 70.
    Nov 2015
    Davenport iowa
    1,144
    You are correct Mike, very high quality made pipe and the sound is a low and throaty.
    1974 Original 70.
    Nov 2015
    Davenport iowa
    1,144
    Well stuck a 24mm mikuni on, seems to have solved the high rpm issue. Needs a little tweaking but definitely much better.
    1974 Original 70.
