Thread: Atc250es no spark
    Homeless Dave's Avatar
    Homeless Dave is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2019
    South Dakota
    255
    Atc250es no spark
    I'm trying to revise a 1987 250es. It currently has no spark and I'm unsure of what to do I tried stripping back spark plug wire I put on a different plug that I knew was good and I know the neutral safety work. the battery kind of held charge for an hour or so ,I determined the starter doesn't work however. but I'm not quite sure what my issue is is maybe the CDI box bad? Im new to CDI ignition, I have only messed with points style ignition. This 3 wheeler has been sitting about 2 years.
    NEPA
    7,051
    Use a NEW plug not a good plug. New. Does the keyswitch seem to work? You can tear the kill switch apart. Sometimes a spider nest/corrosion in there is the culprit. My money is on the Stator. Search out the Ohms and wires to check. Simple to do if it is stator.
    Apr 2019
    South Dakota
    255
    The key switch works as does the neutral and reverse ligths. Headlight and tail lights seen fine. Kill switch is torn apart already. Is the stator by the flywheel or is that the pulser?
    gimmeamidget is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    utah
    436
    Did you test the starter by putting 12 bolts directly to it or just by pushing the button? I would double check switch or fuse.
