My friend has a 83 R and he needs to know how to tighten the drive chain on it.
1979 Honda 110 ATC, CEET gas tank cover, 25X11X9 rear tires
1984 Honda 110 ATC, orignal blue plastics,
1982 Yamaha 175 TRI-MOTO, 26MM Mikuni
Honda US90 ATC, Collecting Dust
2004 TRX450R
I believe that even the 83's had an offset bearing carrier, so you just need to loosen it , and turn it... I think thats how it's done?
My Rides
Yamaha 225 DR For Sale Soon
Yamaha 200E
Honda 110 Need parts? PM me! They're cheap!
Trikes are fun, trikes are fast. They make everyday a pure blast!
Loosen the two bolts at the rear of the singarm and rotate the bearing crrier and retighten the two bolts
84 ATC200X--Wife rode it once, now I can't get it back.
84 ATC250R--Trying to find piston for 300R kit.![]()
85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
I don't have my 83-4 anymore so I can't look. Just wondering if they have the bolt in the middle between the 2 pinch bolts like on my 86. The carrier is egg shaped so moving it forward will tighten then loosen same as going backwards. Keep an eye on chain tension when adjusting. I use spanner wrench.
I want a race honda with reverse.
Alright I'll tell him. We where looking at it was thinking thats how to do it but wasn't sure since his 82 R is different.Originally Posted by ejc042
Thanks for all your help everyone.
2004 TRX450R
... don't forget to loosen the middle "stopper" bolt as well when tightening it.
u need a spanner whrench that honda discontinued i know caz i tryed to buy one now i use a pair of welding "C" clamp vicegrips
83/84 honda act 250r![]()
parts needed new exaust head pipe, shift shaft the list is forever growing
87 yamaha warrior trying to get fixed up for a dd
parts needed upper left ball joint, front shocks, front tires, read break system
