Results 1 to 2 of 2
Thread: how to install headlight bulb in atc 250es
    Dec 2018
    fayetville nc
    35
    cant figure out how to install headlight bulb in 1986 atc 250es
    Apr 2012
    USA
    4,129
    I don't have photos, but it's something along the lines of remove the head light (the two bars of metal on the headlight cage pull out and the whole thing pops up), un plug the wiring at the head light side of the long wire, unbolt the two bolts on the side of the headlight to separate the plastic bucket, headlight cage, and headlight. Then pull the rubber boot back from the headlight and pull the little metal lever up (it's notched so you have to move it so it can come out), then unplug and pull the head light out. Assembly is basically in reverse. It's advisable to not touch the glass on the headlight bulb as the oils from your fingers can cause it to shatter when it heats up (uncommon but happens).
    Also, you can get some more details and photos from the service manual. It starts on page 265.
    http://www.oscarmayer.net/atc/manuals/
    Good luck.
