Results 1 to 2 of 2
Thread: Fuel Tank Interchangeability - 83 ATC200
    Mar 2019
    Charleston, SC
    32
    The Fuel Tank on my ATC was in worse condition than I originally thought... and although it might be repairable by an expierenced welder, I have a feeling if I tried, I would only make it worse.
    So...I was wondering if the tank from different models/years will fit, both on the frame and against the seat
    The only info i found regarding this is here: http://www.3wheelerworld.com/archive...p/t-56838.html
    But I would like to have more than 1 sentance to go off of.
    Thanks
    Apr 2019
    Wellington, KS
    6
    Any 185/s or 200/s tank will work, technically the 200/e/es/m tanks will work as well but are a little bit taller/wider of a tank.
