Results 1 to 7 of 7
Thread: Yt125 exhaust mods
    Aug 2018
    Michigan,USA
    38
    Yt125 exhaust mods
    What modifications can be done to the exhaust to help flow better. Can i take say a new expansion chamber and weld the flange from my yt125 on it or would that not work.
    Sent from my SM-J727U using Tapatalk
    Jan 2013
    minnesota
    5,911
    Exactly what do you want the engine to do?
    I just looked at a yt125 exhaust and just about any other conventional 2 stroke expansion chamber will give you more rpm and mid and top end power. That being said, expansion chambers are rocket science and it may take some experimentation to find something that will work. Also, I seriously doubt any other pipe can easily be made to fit.
    Aug 2018
    Michigan,USA
    38
    Has good low end power. Looking to get some more top end.
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by nmarciano19 View Post
    You will typically loose bottom end power when you increase the rpm range. The entire rpm range typically moves up when you increase the rpm range.
    I just saw this, so you could send the guy a message and ask if he ever figured out exactly which bike it fit and if he has any more of them.
    https://www.ebay.ie/itm/121655367463
    Wichita, Kansas
    1,361
    Please note, any changes requires rejetting.
    The cheapest way for to increase power is to stick a YT175 pipe on it. Youll loose some bottom end power. To combat this, adjust the weights in your clutch. remove all but 10-8 balls. This will put your clutch in spec for the YT175.
    Please note, the entire YT175 top end bolts on. Piston, cylinder, carb, pipe. This will nearly double your HP before any mods on the YT175 top end are done.
    Aug 2018
    Michigan,USA
    38
    Quote Originally Posted by RubberSalt View Post
    Didnt know that the 175 would go on. Ive heard of people on here put DT or IT top ends on, was always curious but never asked about it.
    Wichita, Kansas
    1,361
    They are the same excluding the clutch weights and top end.
    Same cases, cranks, gears, etc.
    The 1980 YT 125 is a weakling. I'd avoid to many mods on it.
