Results 1 to 10 of 10
Thread: 1985 ATC110 shifting-hi/low issue and a rattle
    Aug 2015
    Huntsville,AL
    40
    I picked up a 1985 110 recently and got around to cleaning the carb and starting it today. Its having an issue with going into gear/shifting properly and also had an intermittent rattle that sounds really bad, but it doesnt do it consistently or all the time. I made a video in hope someone has seen or heard this before. Any advice welcome. https://youtu.be/k-09kBDxqxE
    Nov 2015
    Davenport iowa
    1,144
    Make sure your hi/lo gear isn't stuck in between gears . Is that noise happening in neutral or do you have it in gear?
    1974 original 90 X 2
    1974 Original 70.
    ATCKevin's Avatar
    ATCKevin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2018
    Michigan
    179
    I'm curious to hear what some of the guys here say, my 110 has serious going into gear and shifting issues as well.
    Aug 2015
    Huntsville,AL
    40
    It is having difficulty switching from high/low and also shifting, not consistent at all and you have to do some rocking to get it to go into gear...I did get it into gear and it made the noise in gear as well. It's odd, the engine doesn't smoke and sometimes it runs very smoothly and quiet and then sometimes is got that rattle...it really sounds like it's in between gears or something of that nature, but i'm not really sure.
    ATCKevin's Avatar
    Apr 2018
    Michigan
    179
    I think these trikes are known to have shift drum issues, sounds like that could be part of our problems.
    Nov 2015
    Davenport iowa
    1,144
    Quote Originally Posted by Usmoneylover View Post
    It could be the hi/lo gear, I would start there. Put it in gear and engage it to the hi side.
    1974 Original 70.
    Aug 2015
    Huntsville,AL
    40
    I've ordered a service manual so I can start working on it...one more quick question: my deal came with a 1982 parts bike as well, will the engine parts work in the 85 engine? Thanks for the advice so far
    Nov 2015
    Davenport iowa
    1,144
    Yes, most of those motor parts are the same. Glad to hear you are investing in a service manual.
    1974 Original 70.
    Aug 2015
    Huntsville,AL
    40
    Finally got some time to do a light inspection, here is what I found, any input?
    Nov 2015
    Davenport iowa
    1,144
    Something broke. Start looking for broken parts.
    1974 Original 70.
