Thread: 600 Bandit help with carbs
    Jul 2002
    El Paso, Texas
    512
    My buddy has a 600 Bandit streetbike and he is having some problems. Here's the background. He rode it for a year from new, then he put it in storage for a year. He used stabilizer in the fuel and filled the case with oil. When he got back he drained the fuel anyway, then cleaned both carbs really well. He also made sure the air cleaner was clean. Here are the symptoms -- when he revs it from idle it spikes high in RPMs but returns to idle very slowly like it wants to keep revving. It makes it very difficult in 1st and 2nd gears. Everything is stock. Please help.
    Honda
    86 350X - Full Restomod
    85 250R - Legend
    85 Big Red - Clean Original
    85 Big Red - Custom
    Not Honda
    85 Yam Badger 80 - Kids
    99 Pol Sport 400 - Got it FREE
    Jul 2002
    El Paso, Texas
    512
    any ideas?!?!?
    Please help!
    Honda
    85 250R - Legend
    85 Big Red - Custom
    Not Honda
    SE Minnesota
    533
    hmmm
    If it was working fine before he took the carbs apart, I would have to say that they werent put back together properly. Redo the carbs.
    83 YT 175
    85 ALT 125
    Sep 2003
    79
    check this site out. I have a buddy on the site and he has told me that the guys who are on the forum know their stuff.
    they might be able to help you http://www.maximum-suzuki.com/
    02 raptor
    01 lakota sport
    85/86 tri-z
    Us
    727
    i'd say the slides on the carb are stuck. I ran into the same problem on my KZ1000 that i had in my dwarf car. The slides didn't close freely because of the gum in the slides. linkage. Clean this real good with carb cleaner, and spray it with a lube. thant should do the trick. also, clean anything that is atached to tohe linkage, like the accelerator pump, cause that could hold the carbs up. good luck
    Joe
