Results 1 to 15 of 22
Thread: one off fenders cast from originals (fiberglass)
    Jan 2011
    Saskatchewan,Canada
    99
    i have a new set of fenders...i was thinking why not lay up some fiberglass on top the new fenders. They wouldnt have the flex like originals but would they crack and break on the forest trails with branches hitting them etc? Is there a flex agent i could mix into the fiberglass...input anyone?
    devore,ca
    1,042
    I have a set of fiberglass fenders on one of my atc 70's. They look great but don't handle much abuse.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Jan 2011
    Saskatchewan,Canada
    99
    ok..good to know...i probably wont go that route then
    i thought there was some type of plastic that once heated would form to whatever shape a person wanted?
    Mine lasted 3 rides.
    My buddy got a set from the last batch, his broke too...
    Honestly, when guys are making them to sell, they aren't going to make them strong due to excess materials/labor and you'd never come buy to make more, like pharma's do with cancer drugs.
    If I were a fiberglass guy, I'd just add layers after layers, switching the grain etc etc and I'm sure they'd last allot longer than ones people sell us to make money...
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by roonie View Post
    There most certainly is, and it has been around since at least the late 1950's and is what a lot of car and truck interior parts were, and still are made out of. I had the toy below in the mid 60's that would do exactly what you are asking about. One of the stronger types of thermally moldable material is called SMC (for sheet molded compound) which is fiberglass reinforced polyester, and is what we used at Kawasaki to make the jet ski body parts out of, but you asked about hand laid fiberglass and I'm guessing something that one could easily use at home.
    https://en.wikipedia.org/wiki/Sheet_moulding_compound
    Jan 2011
    Saskatchewan,Canada
    99
    yes...i have a brand new set of fenders ive had for years and wanted to use the shape of them to mold another set from. I just recall , somewhere , that there was a plastic sheet that when heated would go all floppy and fall into a form
    Apr 2012
    USA
    4,133
    My 1976 ATC90 had fiberglass fenders (factory I think), they were cracked in the corners by the seat, but otherwise looked great. It seems good sets can be made, but like it's said above, its going to take multi layers.
    Might not be the best example, but a lot of truck toppers are made of fiberglass, they are heavy but hold up well. Toyota even made one for their 86-89 4runner that's more of a SUV body, but the rear section had a removable topper. I'm not 100% sure if it's made of fiberglass, but it's just as heavy lol.
    The melted plastic sheet process I'm pretty sure is what Maier uses (vacuum molded). I wanted to poke around this a bit, but the larger parts would be quite a challenge to get a large enough oven for the plastic sheet and I have a lack of room for the molds. Maybe someday though, or someone else could attempt it =).
    Aug 2016
    East of Worcester ma
    1,370
    Just messin’ around, I only had 3-chip clips and my younger son to hold it in a couple spots. A red Meier (sp) 200x front fender is underneath the maybe 4mm 2-part mix. Hmm not sure how to get it out now again I’m just playing, and the Black is difficult to take pics of. Maybe 6 guys and a vacume bag could do it but who knows.... alright I’m back to lurking...
ID:	258439 Click image for larger version.
ID:	258440 Click image for larger version.
ID:	258441 Click image for larger version.
    About a half hour set time so about 15mins into it you’ve got 5-mins of forming. I’m not recommending this I just thought it was interesting. I’m just happy it didn’t become a permanent part of my countertop.
    Shep
    Jan 2011
    Saskatchewan,Canada
    99
    did you use a release agent?
    Shep
    Aug 2016
    1,370
    Yes, I sprayed everything. This fender with a little trimming around the edges I maybe tempted to use someday. It’s very glossy too, the underside not so pretty though. Click image for larger version.
ID:	258443 Click image for larger version.
    The plastic had the consistency of a fruit roll up when I formed it if that makes sense.
    Shep
    Jan 2013
    minnesota
    5,911
    Shep
    What plastic did you use exactly and what was the process?
    Aug 2016
    1,370
    This link will show you what I used (bjb tc-808 jet black) process- just formed it over an existing fender while pliable. Sets up rather quickly. https://bjbenterprises.com/index.php...jet-black-a-b/
    Shep
    Really just mixed a+b dumped it on the counter let it run flat/level I’m guessing 3-4mm thick, let it set until not tacky then just picked up and layed on the fender molding/pressing while it set up stiff.
    Apr 2012
    USA
    4,133
    Looks like it came out pretty nice, who cares about the bottom side. Pretty neat idea, is that the normal usage for that plastic, or did you come up with that on your own?
    Jan 2011
    Saskatchewan,Canada
    99
    Thats exactly the process im talkin about....now tell me, how tough a beatin will they take ...cause i hunt hard with my machine in the thick forests up here
    Aug 2016
    1,370
    Read roonies post yesterday and you guys were talking about needing heat for forming sheet plastic and this is what I came up with. Oh yes there is heat (chemical reaction) but just warm. I don’t “think” it would hold up to much abuse though. A front fender it’d probably be fine but rears I highly doubt it, it would probably be a bad idea. May work great for like side panels and things. I need a dummy fuel tank and may go this route. Or like a two-part mold for seat foams
    Shep
