So, after doing some searching, I came up with nothing on the site. Nobody seems to be doing much with the Air Foolers and I can't find the
s site anymore.
From what I have found, Big Specht is the only one that has done a modern swap of the rear caliper, but that is it. And it was just off some pit bike.
So my front caliper is good. It is a little spongy, but nothing a fluid change and bleeding won't fix. The rear is completely locked up.
I can get a brand new master cylinder and a rebuild kit for the caliper. If I can, I'd rather swap to something newer and better. If not, I'll continue on with the rebuild.
Does anyone know of modern swaps for either the front or back? Or even if older calipers will swap. For instance, if 200X calipers will swap in, that will help me out tremendously because there are a few modern calipers, like the CR 85, that will swap on.
