Results 1 to 8 of 8
Thread: Needed help
    May 2019
    Michigan
    6
    Needed help
    I have 84 185s with jetted carb and dg pipe but it keeps backfiring what do I do
    6,811
    1983 was the last year for the 185s btw .
    If the head pipe isn’t leaking then you need to richen up the the jetting , if it’s back firing on deacceleration then the pilot jet needs to be bigger , stock is probably a 35 or 38 so a #40 should be a good start . Adjust the air fuel screw for the best highest idle .
    May 2019
    Michigan
    6
    Sorry I forget I have a 40 in it before I had a 35 but I couldn't not go wide open it wanted to die but now I have the 40 in it it runs a lot better but just back firer
    6,811
    Is it back firing on acceleration ?
    Factory carburetor or aftermarket ?
    May 2019
    Michigan
    6
    Just when I let off and factory card
    6,811
    Are you 100% sure the exhaust isn’t leaking at the head ?
    May 2019
    Michigan
    6
    Ya I started it and sprayed it with carb cleaner
    May 2019
    Michigan
    6
    It was the Jets it's running good thanks
