Stator OHMs out at 208 ohms.
Puls generator tests ok.
Ran a test light at the connector between the red and black wire. When you pull it you get light.
Used the test light at the red and black wire up at the CDI and went to ground, I get light.
Ran the test light where the black and yellow wire meets the coil. I get light.
Tested the coil and it phms out within spec per the manual, but I get no light when I use the test light in line with the plug wire or if I remove the plug wire and go straight from the socked to the plug or engine....
What do I have going on here?
