Results 1 to 10 of 10
Thread: New from Michigan
    May 2019
    michigan
    13
    New from Michigan
    New here and new to three wheelers. Wanted one since the 80's machines came out and finally took the plunge. Started out a year or two ago rebuilding three Trail 70's and decided to try my hand at an 83 200X. I like it so much I picked up an 85 350X in about the same condition. Both machines were ridable as is, but needed basic maintenance to be very nice stock machines
    Sulphur Springs,Texas
    1,005
    Welcome to the site Vitamin C! Are you currently rebuilding your 350x? Post up pictures if you can!
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    May 2019
    michigan
    13
    yes currently going through the 350X, the 200X is pretty well done. Im doing them both as original as possible aside from DG pipes on both. Ill get some pics and post them up.
    May 2016
    OH Canada
    1,102
    Welcome to the 'hood. The X are nice trikes and hold value.
    '83 200X
    May 2009
    S.E. Michigan
    1,251
    Welcome to the site from a fellow Michigander!
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    May 2019
    michigan
    13
    I've wanted one of these things since high school. I'm kind of into fixing the vintage stuff at this stage in my life. I've gone through three trail 70's and they are pretty nice machines. I've split the cases on all three, rebuilt the tranny's, cranks, jugs, heads, so that doesn't scare me. So far neither the 200X or the 350X need the cases split. Both the 200X and the 350X got clutch's with the 200X getting a basket and some shifter parts just to tighten up that mechanism. The basket on the 350X was fine as were the plates, but once your that far you may as well replace it. Other than that its regular stuff, plugs, valve adjustments, carb rebuilds, chain/sprockets, all swingarm bearings, complete brake jobs and master cylinders. im sure you get the picture.
    Apr 2012
    USA
    4,133
    Hey, another person from Michigan, welcome to the site, good luck with your two machines. I really liked the 350x too, it's my favorite machine, the ATC250SX is really nice too with being basiclly a sportutility model. To me it feels about as fast as a 200x, but shaft drive and a bit heavier/stiffer ride.
    May 2019
    michigan
    13
    200x
    1983 200X after rebuild
ID:	258781   Click image for larger version.
ID:	258782   Click image for larger version.
    May 2019
    michigan
    13
    350x
    350X mid rebuild
ID:	258784   Click image for larger version.
    Apr 2012
    USA
    4,133
