Results 1 to 3 of 3
Thread: Yt175 crank seals? Split cases?
    Apr 2014
    Australia
    580
    Hey guys
    I am hoping to change the crank seals in my trimoto in the next few weeks and wanted to know if I will need to split the cases? Stator side should be ok. Thanks Ivan
    Slidell, LA
    4,738
    Unless you know the bearings have been replaced before I would split the cases, replace the crank bearings, replace the seals and ensure your con rod big end bearing is still in good working order.
    Apr 2014
    Australia
    580
    Thanks Brendan, I was hoping you would reply! I sent you a message over Instagram! I have brought the bearings and seals and gasket set already! I’ll check out in the next couple of weeks and let you know how I go!
