Results 1 to 15 of 21
Thread: Xr200 bottom end on 200s
    Fullsizechevy9 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2019
    Louisiana
    354
    Is it possible and would there be any real gains from having a 6th gear especially on a modded motor?
    Jul 2018
    TN
    1,065
    Be a pain to start. Have to make a hinged fender or something.
    Another gear might be cool.
    6,798
    The xr 6 speed trannys don’t hold up to the heavy stress of the Atc drive train .
    Jul 2018
    TN
    1,065
    Never thought about the gears being weaker.
    Two tires at over twice the width each; quadruple the (theoretical) traction.....makes a lot of sense.
    Jun 2019
    Louisiana
    354
    Well scratch that idea would be nice to have a 6th gear i always find myself trying to shift just 1 more time
    Jun 2019
    Louisiana
    354
    Hook me up with your supplier lol i could easily.go buy a 200x roller but then ill be looking for alot of.extra stuff plus that takes the fun out of a build. I will be starting to build the swingarm soon im.just going to tear it down and start measuring and mock.it up tack everything make sure all is well before i seal weld everything then i plan on getting a 200x front end and machine a new stem extend the neck make a sleeve whatever i need to do to make it work may just cut the neck off and re weld it give it a little.more.angle. About the 200e i have one that i am thinking about seeing if the bottom.end will.fit in the s frame idk if the starter will clear or.not would.be nice to have electric.and pull start.
    Jul 2018
    TN
    1,065
    An E motor in an S frame requires some cutting and welding.
    The starter won’t clear and you may have issues with the sub-transmission clearing as well.
    Scootertrash's Avatar
    In the sticks
    4,638
    Quote Originally Posted by Fullsizechevy9 View Post
    If you have many more periods yer gonna bleed to death..........
    Jun 2019
    Louisiana
    354
    .lol.hard.to...typ.e....on.this......phone......
    Jun 2019
    Louisiana
    354
    Do you like duck meat glamy? I assume so lol
    Jun 2019
    Louisiana
    354
    Hack it up all you want i cant have anymore kids the wife has cancer
    Jun 2019
    Louisiana
    354
    Finally found a hobby that helps take the stress away i love trikes i have been missing out my whole life should have got into this a long time ago all i can think about is what i want to do to it and looking for the next project before im even done with the first i can already see how addictive they can be and its great to have a place like this you can come and learn so much thanks to everybody who has helped so far
    In the sticks
    4,638
    I'm
    In the sticks
    4,638
    Glamy prefers rooster.............
    Jun 2019
    Louisiana
    354
