Thread: Blaster swingarm on 200s
    Fullsizechevy9 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2019
    Louisiana
    354
    Does anybody think this would be a good swingarm to modify onto a 200s? I can get used blaster swingarms cheaper than the cost of materials to build one from scratch i can get swingarms for around 40$. Unless there is a different swingarm that is better suited to be modified for that application that i can get used off ebay.
    Jul 2018
    TN
    1,065
    From a fabrication standpoint, I'd rather put a 200S on a blaster.
    Jun 2019
    Louisiana
    354
    Nevermind that a banshee swingarm looks like it would be better to modify than a blaster and maybe use a banshee shock also since theres already a mounting point for it on the swingarm im trying to put rear suspension on my s
    Jun 2019
    Louisiana
    354
    Some of them look like the same 4 bolt setup in the rear where the axle carrier bolts up has the 2 top holes and the 2 pivot slots in the bottom i could make mounts to mount up the swinger mock it up make sure its straight and inline before i seal weld it and the end i could cut off and weld the 200s setup on it to mount the axle
    Jul 2018
    TN
    1,065
    ................Do post pics.
    Jun 2019
    Louisiana
    354
    I will im trying to get everything i need together before i start the build i dont want to have a 1 year build. I want to have it all so when i start anybody following wont have to wait months for an update. Now that im looking a little harder the blaster looks to be already offset for chain clearance kinda like the 185s swingarms i see in the kits doesnt look to be much modification needed.
