I may not be a very smart man but i know what love is jenny
Yes to my understanding the piston was the difference in the x versus s but i do plan on doing head work i may just send it off and have it done
Tecumseh sux? Well I tell ya this bike/engine has had many hard hours, still starts first pull and pulls my azz up my steep street and I’m sure using all of its 3-1/2 horses. Doesn’t burn any oil either. It’s just a bit embarrassing to ride around but who cares I don’t. Its the best $150 dollars I’ve ever spent. I even splurged this yr she got a new $5 dollar exhaust.
See she climbs vertical slopes too.....
Shep
To be fair, I should have posted: My experiences with Tecumseh has led me to the opinion that they suck.
Opinions are worth less than a politicians promise.
Cool little minibike. Always wondered if a 200S engine could be horseshoed off in one.![]()
I've always wanted to play around with one of those.
...you look like a monkey F'ing a football riding it but....they're cool!
Love those old school mini-bikes. First bike ride ever was on a Bronco. That’s the one that hooked me even though I was just a terrified passenger.
It sucks to get old
Thanks a friggin' lot Chopper....I been thinking about that little mini bike since you posted it and NOW I got the bug to go build me one. I need it like a punch in the face.....but I wants one.
.....say, you ain't got a bare frame laying around does ya?
That’d be my “wife’s” mini bike it’s the only way I could of brought it home “it’s hers”![]()
Sorry no frames here, u gotta start checking out the local flea markets and classifieds the guy had 4 of them, I shoulda grabbed them all, these bikes seem to never loose value. Mind you there not worth much to start with. I bet you can put one together pretty cheap-
It’s fun to ride but gets hairy above 20mph or so-
Chop was thoughtful and flipped my pic for me, thnx for that
Shep
Here ya go
For Wiseco pistons you bore and hone the cylinder to the specific size on the package and the piston cylinder fix will be correct. For example if your new piston is 66.25mm that is the required bore size, not the size of the piston. The piston is a bit smaller such that the fit is correct. Please use a sunnen rigid type hone not one of those 3 arm cheap hones. The performance comes from the roundness and cylindricity of the bore. For performance a Web cam is a good choice, with either the 10.25 or 12:1 piston. At that point you will become limited by airflow through the head so porting and/or larger valves become required. All depends on how far you want to go but yes a 10:25 will work good with a cam on premium pump gas.
