Results 61 to 75 of 78
Thread: 1982 200e left crankcase cover and crankshaft bolt
  1. #61
    The Open Road
    4,727
    Yep yep yep yep yep yep yep yep yep yep ......fart ......yep yep yep yep yep yep yep yep yep yep yep !
    https://youtu.be/qnb0yfzPHjE
  2. #62
    Fullsizechevy9 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2019
    Louisiana
    354
    Does anybody know the size and thread pitch of the exhaust flange bolts on the 200 e or s or x i think they are all the same
  3. #63
    Jun 2019
    Louisiana
    354
    Going to have to try and drill and tap these cant get them out tried heat tried welding a nut to what was sticking out nothing they are in there and arent budging
  4. #64
    Jun 2019
    Louisiana
    354
    I know its 6mm just not sire of the thread pitch 1.5mm maybe?
  5. #65
    Jun 2019
    Louisiana
    354
    You know what im just going to drill and tap it to the next standard size i have everything here i need wont have to go buy anything
  6. #66
    Jun 2019
    Louisiana
    354
    Bike my s also has a broke exhaust stud
    Sent from my SAMSUNG-SM-N920A using Tapatalk
  7. #67
    Jun 2019
    Louisiana
    354
    Yep yep yep keep bounce bounce bouncing and fart fart farting on that dick dick dick you rode in on
  8. #68
    6,798
    Next time cut the nut off before breaking the stud .
    A quality dermal disk will remove the nut quickly .
    Quote Originally Posted by Fullsizechevy9 View Post
  9. #69
    Jun 2019
    Louisiana
    354
    Ice ice hoe
  10. #70
    Jun 2019
    Louisiana
    354
    I got it broke off like that tried heat they wouldnt budge then welded a nut to what was sticking out not much maybe half inch and they wouldnt budge like that either
  11. #71
    Jun 2019
    Louisiana
    354
    Studs were real corroded hardly any threads left on what was sticking out i guess the exhaust flange got loose and they tried tightening it both studs were broke off when i got the motor
  12. #72
    Jul 2018
    TN
    1,065
    Yeah they can be a pain sometimes. It's really never a good idea to thread ferrous and non-ferrous materials together, but companies continue to do because it's fast and easy.
    Patience. You'll get it.
  13. #73
    Jun 2019
    Louisiana
    354
    Wouldnt have cost much to put 2 stainless studs in it i guess over and over again it was much cheaper for them but im going back with stainless and plenty anti seize
  14. #74
    Jun 2019
    Louisiana
    354
    Would yall recommend taking a few thousenths off this head its kind of pitted in 1 area where it seals just enough to clean it up no more than .005
  15. #75
    Jun 2019
    Louisiana
    354
    Got the exhaust studs drilled and tapped
