Thread: 1986 ATC Big Red 250ES Clutch Help
    MN250R's Avatar
    MN250R is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Minnesota
    285
    Hello,
    I recently changed out my one way bearing with my clutch on my big red. I figured since i was in there, I would replace the clutch pack. I followed my manual making sure the washers were all put back in the correct place etc.
    Now when i shift it into gear, it jumps forward and wants to go. I tried adjusting the play (increase decrease). I have taken it apart 3 times and i get the same results. Starts right up, when i shift it into gear, it jumps forward and wants to start moving. Im at a loss. Any help would be great. Thanks!
    1986 ATC 350X
    6,810
    You put the one way bearing in backwards .
    Easy way to tell if it’s correct is you push the Atv forward in gear not running does it turn the motor over piston included ? And when you push it backwards in gear does it roll freely ? If opposite then it’s installed backwards .
    The China aftermarket bearings are often marked incorrectly .
    MN250R's Avatar
    Jun 2003
    Minnesota
    285
    Thx for the reply! When I shift it into first, it rolls forward, you can hear the drivetrain slowing turning. but I can't push it backwards in first, it won't move.
    1986 ATC 350X
    6,810
    Definitely installed backwards then
    Quote Originally Posted by MN250R View Post
    MN250R's Avatar
    Jun 2003
    Minnesota
    285
    All fixed! Thanks for your help. The China one way bearing was stamped on the wrong side!
    1986 ATC 350X
