Results 1 to 3 of 3
Thread: Off idle bog.
    Nov 2015
    Davenport iowa
    1,144
    Off idle bog.
    All right guys need a starting point here and I know this has been discussed before but searching old threads is a pain imo.
    What we have is a bored and stroked 90, running a mikuni VM 22 carb with a full race cam.
    The trike has a serious bog off idle when cracking the throttle wide open. Tried slide cutaway, Needle those don't help so I'm down to jets I believe. It's running a 100 main and 30 pilot. Any suggestions here? 1/4 - top end is perfect just can't get the snap at low end throttle opening.
    1974 original 90 X 2
    1974 Original 70.
    Mexico
    9,014
    How many turns out is the fuel screw at?
    It sucks to get old
    Nov 2015
    Davenport iowa
    1,144
    Runs best at 3 out Nicko
    Out of curiosity I just tried a 20mm mikuni. Now I have good off idle throttle, no stumble but no fuel on 3/4 throttle on up went from a 90 main up to a 160, no difference. I suspect some of that might be bowl fuel level set to low
    1974 Original 70.
