Thread: 13 hp john deere sabre mower smokes aand quits ?
    fingerlakesny
    2,834
    new to me, Cleaned the carb , started but smoked for a bit. went to mow and under load with the mower engaged after about 20 feet it smokes like a freight train and bog's down a quites unless I disengauge the pto for the mower .. seems like the governor is moving a lot at idle ? any idea's ?
    250r dust runner
    Connecticut
    1,605
    Did you drain the old oil and add the correct amount and proper viscosity? If too much oil or gas leaked into crankcase it will smoke excessively
    Aug 2015
    Idaho
    862
    Check for a dirty crankcase breather.
    fingerlakesny
    2,834
    Started it up today and it seemed to run and mow ok … weird .
    250r dust runner
    Aug 2015
    Idaho
    862
    Quote Originally Posted by dustrunner View Post
    It is weird.....you tried it again without checking anything? Good luck, anyway.
