Good Morning
I have joined the forum to try to get some understanding regarding a problem I have with my trike. Having not long owned this machine I have always had an issue with regard to accelerating the bike. If you push the lever quickly the engine bogs down and eventually catches up, its as if you have a weak mixture ... now though the bike starts but then after a few minutes dies as if its run out of fuel, you cannot get it restarted. If left, you might be lucky in it firing. I have checked the electrics out as per the service manual and can only conclude that the CDI unit might be at fault ? I have got a very feint white spark however. I have checked the stator etc and all continuities and resistances seem fine within limits, I have to point at the CDI unit ? The other problem if it is this, is getting a replacement, can I fit any type ? Mine has the 4 pin and separate 2 pin connector block arrangement, it has hb6 ci511 on it ?
Any help would be greatly appreciated
Mike
