Results 1 to 3 of 3
Thread: 85 250 sx choke problem
    Aug 2019
    Orangeville, Ontario canada
    Tried removing my choke plunger in the carb and broke the needle off on the end and it won't come out what's my solutions here.
    6,811
    Sometimes you can drill the center of the plunger and use an easy out and a little heat around the case at the plunger will help . Lots of penetration fluid .
    6,811
    Just reread your post , if it’s the tip of the plunger that’s stuck then your probably best to find a new carburetor .
