Thread: Front Fender ID
    Mar 2019
    Charleston, SC
    32
    Front Fender ID
    I was looking into getting a new fender for my 83 ATC200, but when I started to look at them they all look different than the one I have currently.
    Can anyone give me a positive ID on this fender?
    Seems like it might be a 200S fender but I am not entirely sure, If it is that just means that someone has swapped the front end on this ATC sometime in the past and I am just now realizing it...
    6,813
    83 was the first year for front suspension and the reason it looks different .
    If you have a 9” front wheel and a 25” tall front tire then that is the original fender .
    Tionesta, PA
    5,747
    What is tough in ID'ing it is the size. The ATC200 front fender from 1983 looks nearly identical to the 1984 - 1986 ATC200S and 1983 ATC185S - it's just scaled up as the "S" models had 22X11-8 tires. So with that said - you would have to measure the width of the fender to be 100% certain.
    Mar 2019
    Charleston, SC
    32
    Thanks guys, If what shortline said is accurate than it is definitely original. I guess the listings on ebay are not accurate, because the pictures are completely different than what I have... I will have to keep looking for one I guess
    6,813
    I believe the 83 regular 200 is a one year only fender so finding one may be a PITA , an 83/ 84 big red or 200m after 83 fender might work .
    Tionesta, PA
    5,747
    Shortline is correct. 1984 and 1985 ATC200M use the identical front fender as the 1983 ATC200. the Big Reds are as different as the 81-82 ATC200 fenders.
