Results 1 to 2 of 2
Thread: Atc200m no compression
    Aug 2019
    Blissville , new brunswick
    I recently had no spark , it was the cdi magnet, had to replace the cham shaft and top of the engine , now i have no compression at all , i put gasket goop on top of all the gaskets , no compression, plently of spark. Now my decompression level is completely loose and freely spins and wiggles; could that be it?
    TTown, Alabama, United States
    845
    Double check the timing, and the valve adjustment as well as the cam gear orientation. Cam lobes should point down at TDC..
    Suicide Hill Survivor
    The rides:
    1981 ATC110
    1982 ATC185
    1983 ATC185s
    1984 ATC200es
    1985 ATC200x
    When the going gets tough, the tough get sideways
