Results 1 to 15 of 18
Thread: What is the model of my tri moto
    Sep 2019
    Langley
    10
    Vin# 21V013229
    Fullsizechevy9 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2019
    Louisiana
    354
    Quote Originally Posted by mase2006 View Post
    Vin# 21V013229
    1983 ytm200k
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Sep 2019
    Langley
    10
    Is it supposed to have electric start
    Jun 2019
    Louisiana
    354
    The vin you gave comes back as 83 ytm200k which doesnt have electric start but i have read where it was possible to put electric start on it with some work the electric start model wad the ytm200ern which was shaft drive with reverse
    Sep 2019
    Langley
    10
    So chain drive has no reverse
    Jun 2019
    Louisiana
    354
    Nope only the shaft drive does
    Sep 2019
    Langley
    10
    Thanks I thought it was 2 stroke so I have been running mixed gas
    Jun 2019
    Louisiana
    354
    No its a 4 stroke drain that gas out the tank and carb and you should be good about the only thing mixed gas in a 4 stroke will do is make it run like crap probably can just drain the tank put fresh gas and go id change the spark plug also once that mixed gas is burnt off out the carb im sure it fouled the plug
    Jun 2019
    Louisiana
    354
    Quote Originally Posted by Fullsizechevy9 View Post
    I seen sombody once fill a cummins uo with gas burn about quarter tank before they realized drained it put diesal and its still running to this day that was about 10yrs ago
    Mexico
    9,018
    Can you post a photo of your trike?
    It sucks to get old
    Sep 2019
    Langley
    10
    Trike pictures
    https://m.imgur.com/a/5HSdBee
    Jun 2019
    Louisiana
    354
    Def a ytm200k
    Mexico
    9,018
    Yep, a 200 4 stroke, your fuel just got cheaper.
    There are provisions for a starter on the engine cases, but it would be a lot easier to buy a 1984 or 85 that came with one than it would be to try and gather up all the parts you would need to make a starter work on that trike.
    There were no chain drive YTM’s that had reverse.
    It sucks to get old
    DSHOT59's Avatar
    DSHOT59 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2009
    sayreville nj
    155
    I have an 83 200 that has shaft drive electric start but no reverse . Wish it did but.
    No trike left behind
    1983 Ytm 200
    1983 Honda 200
    1982 Honda 185s
    1983 odyssey fl 250
    1987 yz 250
    Jun 2019
    Louisiana
    354
    Quote Originally Posted by DSHOT59 View Post
    Yes i should have clarified not all shaft drives will have reverse most do some dont depends on year and model
