Ok, I just fired up the 110 and the motor races. Can anyone tell me how to set the idle? I am dying to ride! :-D
"I am going out of this world.....the same way I came in...screaming and covered in blood."
To set the idle,adjust the screw on the right side of the carb(same side as throttle).If try setting it down some(counter clockwise)it might help and also try checking your throttle slide that connects to the top of the carb because it could be not set in the right slot causing it to rev sky high.
Is that the screw with the spring? There is a few screws on the side of the carb. I will also check the slide. thanx![]()
yes,it is the screw with the spring...check your plug too,it could be running lean.
Yep, it was the slide... it runs fine now... :-D thanx
