Thread: 125m Rattle Help
    Sep 2019
    AL
    125m Rattle Help
    Hey guys I need some help identifying this rattle on my new 85 125m. It happens at mid to high rpm and in every gear and in neutral. Its fairly loud especially when someone else is riding it and I'm behind it. My best guess is it's the broken shift drum brake rattling due to vibrations. I tried searching it, but came up with nothing. Anybody got any ideas?
    Homeless Dave's Avatar
    Homeless Dave is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2019
    South Dakota
    255
    I have logged a lot of time on an 85 125, and i know that the engine vibration at high rpms are really bad. might have rattled something loose. I feel problems with a shift drum wold cause more issues than a noise. check if the exhaust is tight. It could maybe be the chain guard, they rattle a lot if they are loose.
    Apr 2012
    USA
    4,133
    Yea most rattles I've found has related to the exhaust or the chain guard. Kind of doubt it's in the engine, it would be more of an engine noise and rpm would effect it a lot more (like an engine knock, tick etc).
    Sep 2019
    AL
    Ok thank you guys for the input. I will check the exhaust out first. I have already replaced the chain so I do not believe it's the chain guard. Will update ya'll when fixed.
