I finally got me a big red that ran! Three days later, Now it don’t! Engine seemed to purr like a kitten(idle and all). Rode the kids around a bit then I couldn’t help it and got it on two wheels a little. It started making some kind of noise in the motor and turned off when I stopped.
It got pretty hot as I was putting around the yard. I let it sit to cool down. Kicked it and started for a few seconds but cut off. Since then I can’t budge the kick starter. The battery is charging overnight to see if electric start will turn it over. Jump starting did nothing (wheels locked up when I put it in gear). Have I locked this thing up? Kick start would not work with spark plug out either. Is there any other test I can do to figure this thing out?
, or leave the head on but remove the cam so both valves will be closed, and pump the cylinder full of grease with an adapter to go in the spark plug hole. If the piston locked up at the bottom of the stroke that won't help much, but I think it's pretty rare for that to happen.
