Results 1 to 3 of 3
Thread: Fork angle in degrees ???
    oregon
    6
    Hey GUY's what fork angle is best on a custom wheeler ??? Our quad set-ups were like 6 for MX and 7 for dunes yet a totally different animal ... Any thoughts ??? And thanks for any input ...
    Tionesta, PA
    5,744
    You can not go by simply fork angle. You must go by rake angle. The difference is fork angle does not account for axle placement. If leading VS trailing axle - can be a few degrees off either way and a few degrees means a whole lot when it comes to handling. The rake angle is what you are after. Best way to do it - measure off of an existing good handling trike, like a stock 250R.
    devore,ca
    1,017
    The "Trail" number is what your looking for. Track bikes need less trail, dune or open desert bikes need more trail. The fork angle, rake and fork offset are all used to get to the desired trail number. On a trike, in general, you want to keep the trail around 3". A bit more for high speed stability, a bit less for quicker turns.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
