Thread: Tri moto 175 clutch from pw 80
    Sep 2019
    Saskatoon
    3
    Hey everyone, just wondering if I can buy clutch friction and plates for a yamaha pw 80 and use those in my 1982 tri motot 175? They look the same style just not sure if they are the same size. Reason I am asking is because I am having trouble tracking down these for my specific model
    Thanks!
    Feb 2013
    Brazil, Indiana
    728
    3X3-16521-00-00
    Just looked the part number up on ebay and it showed 12 different listings with nos friction plates. One listing had 5 NOS plates.
    Sent from my SM-G965U using Tapatalk
    1979 ATC110
    1983 ATC110
    1984 ATC110
    1984 ATC125M
    1985 ATC110 2 of them
    1985 ATC110 The wife's
    1987 ATC125M
    1985 ATC250ES
    1984 DX225 with 250 timberwolf engine and swingarm. Wolf in DX clothing
    Sep 2019
    Saskatoon
    3
    Yes I saw those listings...Im asking if a PW80 kit will work because I can buy a much more available kit for this and just want to know if that is the same between the trimoto/pw80
    Thanks
    Mexico
    9,018
    Get on a site with a parts fiche and compare OEM part numbers. If they are the same you can use them, if they aren’t then it’s unlikely they would fit.
    I find that if you take an OEM part number and Google it sometimes there are newer machines that come up that share the part and are easier to find.
    Good luck
    Sep 2019
    Saskatoon
    3
    PLATE,FRICTION 3E5-16521-00-00: IS from the PW80
    PLATE, FRICTION 3X3-16521-00-00 : Is from the tri moto
    Theyre so close just not the exact same. On the images I look at they look identical, same number of internal cogs, same style just cant tell if theyre the same diameter and thickness
    Mexico
    9,018
    Maybe buy one and check against your trike plates? Overall Thickness can be adjusted by adding or subtracting plates inside the clutch pack of need be.
