Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 36
Thread: Baja Mini bike
    Jul 2018
    TN
    1,065
    Baja Mini bike
    What a pile of shet. Well...it was free. Tossed the chino motor. It weren't worth fixin'.
    Mock up motor says there's enough room......I have a 185s engine almost built. Should be nice....and stupid uncontrollable. LOL!!!
    Lots to do to make this what I want. BUT, I will start by getting the motor situated and in line with the rear sprocket. Everything else will come later.
    I'm not sure yet but I am seriously considering setting this up as a trike. Time, headache and $$$ will dictate.
    Jul 2018
    TN
    1,065
    One of the first hurdles, post engine mount, will be the shifter. With the pegs so far forward I may have no choice but to go with a suicide shifter. Might as well. The whole dang machine is gonna be a death trap anyway.
    Jul 2018
    TN
    1,065
    Got all 4 motor mounts done today. I'm a pretty lousy welder so I gotta double down and excel at being a good grinder.
    Much to smooth out BUT the engine sits square in the frame and is within a 32nd of the sprockets. I have to change the rear sprocket so I may make a shim for that.
    I work with what I have on hand and rarely BUY metal to work with. The front mount is made from the supports to an old treadmill. The bottom is made from chainlink fence bars. The top mount is made from a shipping support bracket that bolted down the new tire machine we just got at work to the shipping pallet.. No idea what the other mount is made from.
    After a good grinding wheel massage and a smear of paint....well, it'll still probably look like shet.
    Jul 2018
    TN
    1,065
    THe Baja rear sprocket was a different size chain and needed to be replaced. On a whim I was studying what I had on hand....A stock Honda rear sprocket uses a different bolt pattern....BUT, the rivets that hold the shock absorbing assembly are the EXACT same pattern!!! What?!!! So I drilled and drove them out and BAM! It bolts right to the rear wheel hub. What luck??!!!!!
    I bolted everything up and it runs true. Put a travel indicator on it and it's got about .006 runout. I can live that. Also, the chain is now in perfect alignment. Blind squirrel found a nut!!
    Jun 2015
    stonecreek ohio usa
    654
    That should be a lot of fun! I like the other one to. Pit biking on a whole other level.
    Jul 2018
    TN
    1,065
    First nightmare has happened.
    I HAD to put the engine in the way it is to get it to fit. .........BUT it is impossible to put a carburetor on using shelf parts. I spent several hours sifting through chinez-bay intakes and NOTHING will fit and clear the frame.
    ...nothing else to do but MAKE an intake manifold. With little more than hand tools...this will take some time. uggghhhh!!!!
    Jul 2018
    TN
    1,065
    Got the first of 3 parts made. Engine side.
    Still need to make the carb side and the connection tube.
    Used some 3/8" thick 1018 I had sitting around. Lathe bored the hole first in a 4 jaw chuck, then drilled the holes. Then saw/filed the profile & sand blasted it.
    My hand work isn't the best but the worst of it won't show once it welded, painted and installed.
    Jul 2018
    TN
    1,065
    Got it done. ...just hope it'll run. Pretty sharp angle. But let's be honest. The engine won't have to be super efficient to move this thing, so as long as it can be tuned to run smooth and reliable it'll be fine.
    Still needs a liberal coat of paint to hide my lousy work.
    But it clears the frame and will sit neatly under my leg.
    Now I need to start building the exhaust I suppose...or maybe the battery box.
    Not sure what I will tackle next.
    May need to take a step back for a minute just to make sure I'm not overlooking any elephants in the room.
    Any potential problems any of ya'll see, please point them out.
    One mistake I noticed AFTER i had it finished welded was I made the carb sit level with the frame sitting level BUT the frame doesn't ride level. The front sits up a little so it'll be tilted back about 15 degrees unless I lower the front, which I am no opposed to doing. I never liked the front end sitting up as high as it does anyway.
    Thanks!
    Jul 2018
    TN
    1,065
    Moved to the rear today. Still looking for stuff I need to make the exhaust SO, I got (2) .50 caliber ammo cans mounted. 3 mounts for each can and rock solid. Gotta cut the handles off and they'll get repainted when all the fab work is done.
    One side will house the battery, rectifier/regulator and as much of the wiring as I can to keep everything clean looking.
    THe other side is still up for debate. Storage or a fuel cell. I don't think I will ever fond a tank that will fit up there and look decent so I may put a fuel cell in there and feed the carb with a Mikuni pulse pump.
    Jul 2018
    TN
    1,065
    Funny. That last pic looks wonky but they are straight. I set them with a level to the frame.
    Jul 2018
    TN
    1,065
    My only other option (sans spending $$$) is a desert tank I have. It actually clears everything and making the mounts is gravy work......but I can't decide if it's OK or looks fackin' shtoopid. LOL
    It's just sitting up there now. It will actually sit down a little better if the mounts were in place.
    The front is OK. The bars all clear as do the forks. It's the junction between the seat and tank that is outta place.
    It's a fat sucker but is seems comfortable.
    [img][/img]
    Jul 2018
    TN
    1,065
    Well scrap that. No possible way to clear the carburetor. Mehh.
    Jun 2015
    stonecreek ohio usa
    654
    That's looking good I like It
    Jul 2018
    TN
    1,065
    Had to order another mandrel bent U pipe. Soon as it's here I will start the exhaust.
    ANYONE have a suggestion for a muffler that would be nice and quiet???
    The tractor muffler I used on the Goblin sounded nice but was a little louder than I want for this machine. Since NONE of the exhaust has been fabricated, I am somewhat wide open on muffler possibilities and locations. I haven't even decided which direction to route it yet.
    Jun 2009
    Leander TX
    2,217
    I bet you could copy some shifter ideas from cruiser forward controls?
    Maybe use some junkyard sportbike rear sets?
    Basically, pivot a shift lever by your foot with a pushrod back to another on the engine? Like a 350X rear brake pedal if you know what I mean.
    Maybe adapt an OEM Honda exhaust from a 200X or maybe an older, small XR/XL thumper?
    Not sure if anything would be more quiet than that?
    Maybe on old school little supertrapp with few disks?
    How important is ugly to your exhaust solution? Like using a car muffler ugly? Hidden in an ammo box?
