Results 1 to 8 of 8
Thread: us90 tires and rim alternative.
    Oct 2019
    NY
    just picked up a 70-71 us90 with all 3 balloon tires split.i want to run the 4-snow tires on the front and rear.can i use the original hubs on some other year and model rim.and what would that be.im sure other people have done this feel free to post pictures i would like to see what it would look like.thanks
    Pekin IL
    529
    I believe they made adapters to be able to run the 3x100 atc90 rim.
    Sent from my moto x4 using Tapatalk
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    Trikefest 2012,13,14,15
    Williamstown PA
    5,825
    Run a balloon knobby on rear. 4 snow tires have no protection and you will plug them alot on the front. Rear is ok. You can just refill bolt in alum rims for the 3x pattering or have hub machined down and have 4x110 bolt circle welded to them. Alot of things can be done at a local machine shop.
    6,811
    Dratv.com used to sell the hub adapters .
    I haven’t looked to see if their still available .
    Pekin IL
    529
    You could just switch the axle out too, there pretty cheap. There's a picture on here somewhere of a us90 with blacked-out rims and hubs that looks really good.
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    Jun 2013
    Oceanside, CA.
    614
    You have several options. 3 bolt adapter plates bolting to original hubs or replace front and rear axle assemblies with '75 and newer 90/110 assemblies.
ID:	260490 Click image for larger version.
ID:	260491 Click image for larger version.
ID:	260492 Click image for larger version.
ID:	260493 Click image for larger version.
    "HJ" Click image for larger version.
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
    San Marcos Ca.
    715
    Quote Originally Posted by HairyJR View Post
    Hey HairyJ , very nice collection.
    * 1970 US90 Red
    * 1985 ATC 200s
    Cold Lake, Alberta, Canada
    3,019
    I bought used rims and tires from a member on here for my camo trike build. The adaptor plates were already on it so I can't chime in on their source, sorry.
    http://www.3wheelerworld.com/showthr...ight=camo+us90
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
