Results 1 to 8 of 8
Thread: Tri moto 200k won't stay running
    Sep 2019
    Langley
    10
    Went for a ride a through some mud and puddles then died and felt weird to pull it would start then run for a few min then die. Towed it back cleaned spark plug, air filter. It it was hard to get started but felt weird and lots of backfiring then died again. Dose anybody know what could be wrong? Please help.
    Scootertrash's Avatar
    In the sticks
    4,638
    How deep was the mud/water?
    Did you suck water and/or mud into the carb or engine?
    Jul 2018
    TN
    1,065
    Easiest thing to try, cut off the gas and open the bowl drain. Drain the carb then try again. If that does nothing, pull the carb and clean it. Sounds like you got yourself some water in the carburetor.
    Sep 2019
    Langley
    10
    Yes I got water in the carb it wasn't super deep. We where running it on mixed gas before we found out it was a 4stroke
    Mexico
    9,018
    Pull the lid off your airbox and check if there’s any water in there. If there is pull that funny looking plastic thing off the bottom of the airbox and let the water drain out.
    If you have the stock foam air filter clean and oil it and put it back on. If you have a paper filter replace it.
    Remove the small screw on the bottom of the float bowl of your carburetor and drain it. Then turn the peacock on and let a bit of clean fuel run though it before putting the drain bolt back in and filling the bowl with fresh fuel.
    Pull the dipstick out of your oil and check if it’s clean. If it looks milky at all that’s water, change your oil.
    You should be able to start and run the trike just fine after all this.
    Sep 2019
    Langley
    10
    There is just a hole in the bottom ni water
    Nov 2013
    Oxford CT, New Haven County
    984
    Jumped timing. Mine did ... AND i was crossing a muddy stream when it died. the only difference was, mine wouldn't start back up. but you may have only jumped a tooth or two. On mine, the key way holding the timing gear on broke away and the gear was free to spin.
    Nov 2013
    984
    I think theres a whole post on my timing issues here someplace too...
