Page 2 of 2 FirstFirst 1 2
Results 16 to 24 of 24
Thread: Big Red Speedo Light question
    Apr 2012
    USA
    4,133
    Can you add a couple photos of the socket? Maybe we can spot something.
    Also, you happen to have a multi meter and know the basics on how to use it?
    Aug 2015
    Idaho
    837
    It plugs into the main harness, anyway. You had a hunch it is a ground issue and there are only a couple connections to check. It shouldn’t be difficult to check the base of the socket. You may have to cut the loom where it is heat crimped, to get the boot to slide down enough to access that. See the picture above-it’s not a great connection from the go. Again, check that green wire at the back of socket. Good luck!
    Nov 2013
    NV/MI
    81
    So here are some pictures I took.
    Picture #1 is of the wires going into the socket.
    Picture #2 is of the light switch on but the light isn't working.
    Picture #3 is of the light switch on and the socket touching the speedometer housing. Click image for larger version.
ID:	261025Click image for larger version.
ID:	261026Click image for larger version.
    Honda Trikes
    1983 Honda ATC 70
    1985 Honda ATC 70 x2
    1984 Honda 125M
    1985 Honda 250es
    Honda (non trikes)
    1968 Honda z50
    1969 Honda z50
    1970 Honda CT 70H
    1972 Honda CT 70H
    1973 Honda CT 70
    1993 Honda 300 4x4
    Nov 2013
    NV/MI
    81
    Sorry, trying not to beat a dead horse here. I went through all the connections again and cleaned them again. They started off clean since its been in the high desert its whole life there is zero rust on anything.
    Honda Trikes
    1983 Honda ATC 70
    1984 Honda 125M
    1985 Honda 250es
    Honda (non trikes)
    1968 Honda z50
    1969 Honda z50
    1970 Honda CT 70H
    1972 Honda CT 70H
    1973 Honda CT 70
    1993 Honda 300 4x4
    Apr 2012
    USA
    4,133
    Interesting situation, sounds like a bad ground connection. Clearly the brown wire has good connection. I think the easiest test would be to disconnect the green wire only and ground the wire and see if the bulb comes on. If not then I'd suspect the wire is broken internally in the insulation. If it works, then I think we'd need to further test your grounding, or maybe something isn't hooked together right.
    Do you have a multi meter and a basic understanding how to use it?
    Nov 2013
    NV/MI
    81
    I took the harness that comes with the speedometer kit which is an extension to the main harness out and plugged it directly to the harness. Same issue. I might just get a small wire and have it tucked into the grommet and overlap it so it touches the house so it will ground and work correctly.
    Honda Trikes
    1983 Honda ATC 70
    1984 Honda 125M
    1985 Honda 250es
    Honda (non trikes)
    1968 Honda z50
    1969 Honda z50
    1970 Honda CT 70H
    1972 Honda CT 70H
    1973 Honda CT 70
    1993 Honda 300 4x4
    Apr 2012
    USA
    4,133
    Since it's just bullet terminals, try to plug it into the tail lgiht socket (green to green, brown to brown). If the tail light works and the bulb socket doesn't power the bulb, the green wire is bad. If it works, there's another electrical gremlin going on or hooked up incorrectly (photos of what it connects to wouldn't hurt).
    Aug 2015
    Idaho
    837
    With-in the speedometer light harness, there are two green wires connected together, underneath the plastic loom.
    Nov 2013
    NV/MI
    81
    I will take a look at it again. Thanks guys
    Honda Trikes
    1983 Honda ATC 70
    1984 Honda 125M
    1985 Honda 250es
    Honda (non trikes)
    1968 Honda z50
    1969 Honda z50
    1970 Honda CT 70H
    1972 Honda CT 70H
    1973 Honda CT 70
    1993 Honda 300 4x4
