Results 1 to 7 of 7
Thread: Atc70 help
    Apr 2014
    Australia
    580
    Atc70 help
    Hey guys
    I have a atc70, it has a 74 motor in it and it’s a 80 frame. I’ve done the piston, rings and valves. It had some sort of Chinese carb with it. It seems to idle fine but when I give it gas it bogged down. Then I got a 79 to 85 oem used carb for it and put a kit through it. Put the original air box on it and still didn’t seem to run right. I changed the clip to all positions and air screw. Still doesn’t seem to run right.
    I know it’s a 74 motor but will the 78 to 85 carb make that much of a problem?
    Should I buy a 73/74 aftermarket carb for it and try that? Is the 73/74 intake manifold different to the 78 to 85?
    Don’t know what to do anymore, might have to sell it off.
    Thanks ivan
    6,819
    Change the points and condenser . The points are what advances the timing and will cause it to not want to rev up .
    Apr 2014
    Australia
    580
    You think that will fix the problem? So just put new points in and a condensor?
    Nov 2015
    Davenport iowa
    1,144
    [QUOTE=ivan-083;1503078]You think that will fix the problem? So just put new points in and a
    Sent from my iPhone using Tapatalk[/QUOTE
    Shortline is pretty knowledgeable with these things. It’s a pretty good bet that he is correct. Also points and condenser are a pretty inexpensive try compared to chasing your tail with carbs. New sparkle never hurts.
    1974 original 90 X 2
    1974 Original 70.
    Apr 2014
    Australia
    580
    [QUOTE=DAM shop;1503089]
    Quote Originally Posted by ivan-083 View Post
    Thanks Boys I’ll order a set or points and condenser! What points should I get and condenser? Always buy oem ones.
    6,819
    Yes OEM is best
    Cold Lake, Alberta, Canada
    3,019
    Heed the advice from shortline! In my experience these things live and die based on their ignition systems; and I would beg to guess more than one pull start has fell victim to abuse due to poorly adjusted points or bad condensers.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
