Does anybody have a part number or a place that I can go to to buy a gasket that's between the carb and engine? It's the one with 2 bolts that bolts directly to the engine. I've searched and can't seen to find it.
Thanks in advance!
Thanks in advance!
1974 Honda 90 1st 3 wheeler (sold)
1985 Honda 200M (sold)
1985 Honda 350 Odyssey (sold that was a big mistake)
1985 Honda 250SX 3rd owner
I read that as being the intake. As far as I know, they aren't available new. You will have to look for a used one.
I believe they are the same as the one from a 250es, i know i have one of those some where, ill look around to see if i can find it, ill give it to you if you pay for shipping (assuming i can even find it).
Currently : trx400fw, ct70, 250es,200x, xl80s, 350x, 350x, Trx250X,ALT185
i thought you were referring to the intake boot....
Now I see what you're talking about and I'm not even sure this was put together right from the guy I bought it from or maybe even before him, who knows. I'll go by the numbers of the diagrams so you can see what I have:
#8 Carb insulator has O ring #22 which I'm sure I need and I also have carb insulator #9 but only has an O ring on one side of it. When I pulled this apart months ago, the 2 O ring pieces were together and siliconed. And the gasket I referenced earlier was on the head. Now do I need both carb insulators and if so, O ring #23 is no longer available, so would #22 work on the #8 carb insulator? I can try to load pics later.
Most auto parts stores sell gasket paper, or a piece of cereal box cardboard is often used...
